Roger the Dodger
Casio Illuminator battery change.
A week or so ago, I posted a pic of an old Casio that I haven't worn for years, and mentioned that I had to change the battery(s) in it. This is an older Casio Illuminator which has an EL (electro-luminescent) backlight that lights up the whole dial. This is a seperate part of the movement and uses a different cell to the one for the module. After I mentioned this, I was asked what was involved, so did this series of pics and steps for anyone else who has a watch that's similar.
This is the watch.
Casio battery change.
First, remove the caseback and gasket...
This plastic spacer needs removing, and is released by gentle pressure on this tab with a screwdriver.
This reveals the EL unit sitting on top of the module.
The EL unit is removed in the same way as the spacer, by gently easing this tab with a screwdriver.
Once removed, the module and its cell are revealled.
The cells are a 371 (SR920SW) for the module and a CR1616 3v Lithium for the EL unit.
The module cell is released by unhooking the retaining cage here...
Don't forget to short the +ve (top) of the new cell to the AC (All cancel / all clear) terminal or the watch may not work properly. Do this with the forceps. BTW, the small tab labelled 'push' is depressed to remove the stem if required. I did take the whole module out while I had it apart, and put the case in the ultrasonic machine to clean it.
Now for the EL unit. Here it is with the old cell in it, and the new one by the side...
The cage is released exactly the same as the module one...it just unhooks from here...
Successfully swapped over.
Reassembly is the reverse process, however, just make sure that you get this spring...
....through the hole in the body of the EL unit. Don't trap it underneath.
Finally, replace the spacer, making sure it's clipped in properly, clean and grease the gasket and refit the caseback. Reset the analogue hands and digital display according to the instructions and test out the EL unit.
Casio Illuminator
Hope this will be of use to someone, and thanks for looking.
you must still have a steady hand and good eyes rog, id end up knackering it, im better on cars with a hammer and socket set.
Image result for broken down car
I hate battery changes on digital watches, so I get someone else to do it!  Mind you, I haven't changed an analog watch battery either!  :laugh:
