Can any of you car gurus recommend a glue that will re-attach the trim to my car bumper?  There are so many different types of silicone/epoxy/super glue that don't work on certain types of plastics that I have no idea which one to choose or, indeed, if any will work at all.  Or will glue just pull the paint off the bottom edge of the bumper as soon as I scrape across the next speed bump (of which there are thousands around here)?
Just now, Davey P said:
I stand corrected, it appears that Nigel doesn't know the correct answer after all......... :laughing2dw:
i do i do, remember that merc s550 amg i brought over from ireland? the big blue b@stard on the 57 plate? Well the leccy boot was a pain in the arse, so i disconnected the cable, drilled a hole above the number plate and threaded the cable through the hole and put a cable tie loop on all i had to do was pull that with my finger never got locked out again!
bloody merc electrics...
i'll find a pic of the bloody thing later.
Just now, rhaythorne said:
Unfortunately I'm utterly hopeless at anything like "drilling", "riveting" or anything remotely D.I.Y... unless D.I.Y stands for Destroy It Yourself, in which case I'm an expert :laugh:
Gluing I can just about manage, probably!
drill hole cable tie will do
24 minutes ago, Davey P said:
If you believe the annoying adverts, Gorilla glue will stick almost anything to almost anything, so that might be worth a try... :tongue:
Yep, I looked at this, but was put off by the fact that they omit the word "plastic" from all the other things they say it sticks to (at least on the outside packaging).  Also it appears to be aimed more at absorbent materials into which the glue can expand and that wont work in this case.
But thanks for resisting the temptation to suggest that I sell the car and buy a Porsche :laugh:
23 minutes ago, ziggy1024 said:
U-POL Tigerseal Black Pu Adhesive & Sealant - 310ML
But a better answer might be a new clip, if it's a standalone bit that's broken/missing?
That looks promising, I shall investigate.
40 minutes ago, Bonzodog said:
Double sided automotive tape might do the job.
  That sounds interesting too.  I'd looked at double-sided tapes but they come with the same caveats as the various glues in that they don't stick certain types of plastics.  An automative variant might be a good bet though.
It was tempting mate.... very tempting....... I think that might be my standard answer to most things in future :yahoo:
That tiger stuff or similar is what I’ve used in the past. Just ask at your local motor factors and they’ll sort you out. It won’t come lose after a bit of that on it.
Hi having just gone back into car accident repair I would like to offer some help if I can. Without knowing what kind of trim it is I will give you a few options. Try and look inside the groove of the trim, sometimes they're reinforced with metal strip that runs all the way inside the groove but covered by itself if you follow, with some pliers try to close the gap where it's come off, if successful it will push back on, if slack make the groove smaller. Now if its tougher plastic then warming with a heat gun and closing the groove may help (not to hot don't melt it) warm it with heat gun, close gap with pliers, hold until cooled, the plastic will then retain its shape. If non of the attempts work then try sikaflex from Halfords, eurocarparts, amazon etc. Use a little bead along the fallen part groove and use masking tape  to support overnight. Please feel free to message me if I can be of any more help
  • 2 weeks later...
