Gen 2 RAF Seiko repair
Arnie
Hi Everybody - my first post, forgive me if I make any rookie mistakes:
I have an RAF pilot's Seiko watch, the type issued to Harrier pilots in the mid-90s (seems to be referred to as the 'Gen 2 Chronograph' and has the P on the face). Over the last couple of years it started occasionally losing time, and now it's stopped altogether. I changed the battery, that made no difference, so I'm guessing that it needs a repair or perhaps a new movement.
I would be very grateful if someone could advise me how to get it repaired in the UK. Thanks in advance for your help
Arnie
18 answers to this question
Hi jmm1 - I just picked up the watch and the stopwatch hand was running, and so I played around with that for a while. The stopwatch function seemed to work ok except that when you reset it the hand didn't always return to the correct position. The normal second hand was not working. I then opened up the watch, removed the battery and cleaned the 2 copper-coloured contacts underneath (which looked pretty clean if I'm honest). However, when I replaced the battery the stopwatch was no longer working and so the watch seems lifeless again.
Any ideas...?
Any ideas...?
Is there a plastic insulation disc under the negative contact
I would test the battery voltage first. I put a new Renata in one of my watches recently and it stopped again a couple of weeks later. When tested the battery was only reading about half what it should. The next battery I fitted I tested first and it's been fine since.
x
5 hours ago, jmm1 said:
I could be wrong, but when you replace the battery on these don't you have to re set the watch movement. The movement has one or two holes in the back where by you have to put a pin or something similar inside to reset. Like I say I could be wrong.
There is a good photo of the movement here - mine is exactly the same as this. Please could you take a look and see what you think
9 hours ago, jmm1 said:
The link is not working mate.
Ah sorry - the link in full is:
https://www.seiko7a38.com/apps/forums/topics/show/7874323
3 hours ago, spinynorman said:
Use a bent paperclip. One end in the hole marked AC, the other on the battery. All being well, the watch should start.
Thanks, I gave it a try. The stopwatch function has started working again, but the reset (i.e. send the hand back to the 12 o'clock position) is intermittent and sends the hand to a random position. The normal second hand isn't running so I'm guessing the main watch hasn't been jump-started
I don't have any other suggestions. @tick-tock-tittle-tattle has experience with other 7txx movements, he might have some ideas.
Hi I'm a little late to the party....did someone mention 7Txx movements @spinynorman :biggrin:
My experience is mainly with 7T32, 7T42, and 7T62 based watches Seiko/Pulsar/Lorus
Sounds like poor connections to the circuit block if there is power getting through then stopping again. If you feel confident it might be worth removing the battery plate and release the screws on the next layer down that make connection to the block and then tighten them up again.
I would also have a general look around for a sulphur green deposits, a sure sign of a battery leak.
Can you take a photo of your watch movement so I can have a zoom in to check it over.
How do I attach a photo to a post?
