Scurfa Diver One battery replacement & seal?
Eddiex
Newbie question alert!!
My Scurfa Diver One stopped working so I'm guessing that I need a new battery. I have some basic tools so removed the case back and I see that it has a Renata 371 battery fitted. I'm assuming that it is the original battery so it makes sense to replace with another one.
With regard to the case back seal - Having done a little searching, I see some people recommend using some sort of seal lube (?) on reassembly to ensure the watches  water resistance. Is this good practice or should I just turn the case back up nice and tight? The seal and inside surfaces look bone dry to me when I opened up the back.
6 answers to this question
Thanks @JoT
Not seen that before and as you say looks easy to use - pop the seal in, give it twist and refit to watch Excellent!
I hadn't thought of replacing the seal to be honest but I see, in the link you gave me, that Amazon have neatly bundled a package of silicon and gaskets as a suggested purchase!! :)
Am I correct in thinking that I’m order to release the battery I need to release the small screw to the right of the actual battery? To me , it looks like the small
metal tang with the hole in it is holding it in place?
Sent from my iPhone using Tapatalk
No need to undo screw just put a bit of peg wood/ tooth pick in the hole and slide over ,
