Watch Battery Info.
Griff
e.g. a 317 is equivalent to RW326, SR516SW etc.
Volts Drain Diameter Height Ref. Rayovac Japan* Renata Citizen IEC Bulova Timex Seiko Energizer Varta
1.55 LS 11.6 4.2 301 RW34 SR43SW 1 01 SR43 226 D SB-A8 BSR43L 528
1.55 LS 11.6 5.4 303 RW32 SR44SW 9 08 SR44 A SB-A9 BSR44L 521
1.55 LS 7.9 5.4 309 SR754SW 16 SR48 70T 526
1.35 LM 11.6 5.4 313 RW52 13 MR44 501
1.55 LS 7.9 1.6 315 RW316 SR716SW 40 56 SR67 614 HA SB-AT BSR315L 530
1.55 LS 5.8 1.6 317 RW326 SR516SW 53 58 SR62 616 CA SB-AR BSR317L 566
1.55 LS 5.8 2.7 319 RW328 SR527SW 60 SR64 615 SB-AE/DE BSR319L
1.55 LS 6.8 1.6 321 RW321 SR616SW 38 73 SR65 611 DA SB-AF/DF BSR321L 540
1.35 LM 7.9 5.4 323 RW58 8 MR48 C SB-C3 506
1.35 LM 7.9 3.6 325 RW57 5 MR41 SB-C1 507
1.55 LS 7.9 3.1 329 RW300 SR731SW 24 BSR329L 525
1.55 LS 5.8 1.2 335 RW335 SR512SW 68 622 SB-AB
1.55 LS 4.8 1.6 337 SR4165SW
1.55 LS 6.8 1.4 339 SR614SW 52
1.55 LS 7.9 1.4 341 SR714SW 39 627 567
1.35 LM 11.6 3.6 343 RW56 3 MR42 218 B 509
1.55 LS 11.6 3.6 344 RW36 SR1136SW 12 SR42 242 BSR42L 529
1.55 LS 7.8 1.2 346 RW346 SR712SW 66 628 SB-DH
1.55 HS 11.6 3.6 350 14 SR42 604 549
1.35 LM 11.6 4.2 354 RW54 4 MR43 SB-C8 508
1.55 HS 11.6 5.4 357 RW42 SR44W 7 08 SR44 J SB-B9 BSR44H 541
1.55 HS 7.9 2.1 361 RW410 SR721W 46 53 SR58 X SB-BK/EK BSR58H
1.55 LS 7.9 2.1 362 RW310 SR721SW 19 29 SR58 601 S SB-AK/DK BSR58L 532
1.55 LS 6.8 2.1 364 RW320 SR621SW 31 34 SR60 602 T SB-AG/DG BSR60L 531
1.55 HS 11.5 1.6 365 RW418 SR1116W
1.55 LS 11.5 1.6 366 RW318 SR1116SW 46 608
1.55 HS 9.5 2.1 370 RW415 SR920W 36 51 SR69 620 Z SB-BN BSR370H
1.55 LS 9.5 2.1 371 RW315 SR920SW 30 31 SR69 605 SB-AN BSR371L 537
1.55 LS 9.5 1.6 373 RW317 SR916SW 41 45 SR68 617 WA SB-AJ/DJ BSR373L 539
1.55 HS 6.8 2.6 376 SR626W SR66 619 MA
1.55 LS 6.8 2.6 377 RW329 SR626SW 37 39 SR66 606 BA SB-AW BSR377L 565
1.55 LS 5.8 2.1 379 RW327 SR521SW 50 59 SR63 618 JA SB-AC/DC BSR379L 520
1.55 HS 9.5 3.6 380 SR936W SR936
1.55 LS 11.6 2.1 381 RW30 SR1120SW 34 27 SR55 317 SB-AS/DS BSR55L 533
1.55 LS 7.9 3.6 384 RW37 SR41SW 10 18 SR41 247 SB-A1/D1 BSR41L 527
1.55 HS 11.6 4.2 386 RW44 SR43W 6 41 SR43 260 H SB-B8 BSR43H 548
1.35 LM 11.6 3.6 387 RW51 M 502
1.55 HS 11.6 3.1 389 RW49 SR1130W 17 15 SR54 626 SB-BU BSR54H 554
1.55 LS 11.6 3.1 390 RW39 SR1130SW 11 24 SR54 603 SB-AU BSR54L 534
1.55 HS 11.6 2.1 391 RW40 SR1120W 23 30 SR55 609 L SB-BS/ES BSR55H 553
1.55 HS 7.9 3.6 392 RW47 SR42W 2 13 SR41 247B K SB-B1 BSR41H 547
1.55 HS 7.9 5.4 393 RW48 SR753W 15 SR48 255 F SB-B3 BSR48H 546
1.55 LS 9.5 3.6 394 RW33 SR936SW 27 17 SR45 625 SB-A4 BSR45L 524
1.55 LS 9.5 2.6 395 RW313 SR927SW 25 48 SR57 610 LA SB-AP/DP BSR57L 523
1.55 HS 7.9 2.6 396 RW411 SR726W 29 52 SR59 612 V SB-BL BSR58H 556
1.55 LS 7.9 2.6 397 RW311 SR726SW 26 28 SR59 607 N SB-AL BSR59L 536
1.55 HS 9.5 2.6 399 RW413 SR927W 35 44 SR57 613 W SB-BP/EP BSR57H 543
*Japanese part numbers are used by Panasonic, Sony, Maxell and Toshiba.
  • 2 weeks later...
complete abracadabra to me....
Gregor
Not too complicated Gregor although it would have helped if the diameter, height etc headers had lined up with the details underneath.
Basically its just a list giving interchangeable part numbers for quartz batteries from different makers although most use the Renata numbers now.
The diameter, height etc table is in case you have an unmarked battery or no battery to compare then you can measure the size available.
Very neatly formatted Hawky but you haven't got the standard ref numbers that every body uses which were on Griffs listing. i.e 371, 379 etc. etc. to make it the definitive list.
  • 5 months later...
Watch size and capacity info:-
Watch Batteries and Calculator Batteries
25.4mm = 1.00 inches
WATCH
Dimensions : BATTERY No. : Nom. Capacity :
4.8 x 1.6 mm 337 8 mAh
5.8 x 1.2 mm 335 5 mAh
5.8 x 1.6 mm 317 10 mAh
5.8 x 2.1 mm 379 16 mAh
5.8 x 2.6 mm 319 21 mAh
6.8 x 1.4 mm 339 11 mAh
6.8 x 1.6 mm 321 14.5 mAh
6.8 x 2.1 mm 364 20 mAh
6.8 x 2.6 mm 377 28 mAh
7.9 x 1.2 mm 346 10 mAh
7.9 x 1.4 mm 341 15 mAh
7.9 x 1.6 mm 315 19 mAh
7.9 x 2.1 mm 362 23 mAh
7.9 x 2.6 mm 397 32 mAh
7.9 x 3.1 mm 329 37 mAh
7.9 x 3.6 mm 384 45 mAh
7.9 x 5.4 mm 309 80 mAh
9.5 x 1.6 mm 373 29 mAh
9.5 x 2.1 mm 371 38 mAh
9.5 x 2.6 mm 395 55 mAh
9.5 x 3.6 mm 394 84 mAh
11.6 x 1.6 mm 366 40 mAh
11.6 x 2.1 mm 381 50 mAh
11.6 x 3.1 mm 390 80 mAh
11.6 x 3.6 mm 344 105 mAh
11.6 x 4.2 mm 301 120 mAh
11.6 x 5.4 mm 303 175 mAh
6.8 x 2.6 mm 376 27 mAh
7.9 x 2.1 mm 361 23 mAh
7.9 x 2.6 mm 396 32 mAh
7.9 x 3.6 mm 392 45 mAh
7.9 x 5.4 mm 393 80 mAh
9.5 x 2.1 mm 370 38 mAh
9.5 x 2.6 mm 399 55 mAh
9.5 x 3.6 mm 380 82 mAh
11.6 x 1.6 mm 365 40 mAh
11.6 x 2.1 mm 391 50 mAh
11.6 x 3.1 mm 389 80 mAh
11.6 x 3.6 mm 350 105 mAh
11.6 x 4.2 mm 386 130 mAh
11.6 x 5.4 mm 357 190 mAh
3V LITHIUM Button Cell Batteries
Chemical System: Dimensions : WATCHBATTERY No. : Nom. Capacity:
9.5 x 2.7 mm CR927 30 mAh
10.0 x 2.5 mm CR1025 30 mAh
12.5 x 1.6 mm CR1216 25 mAh
12.5 x 2.0 mm CR1220 38 mAh
12.5 x 2.5 mm CR1225 48 mAh
16.0 x 1.2 mm CR1612 35 mAh
16.0 x 1.6 mm CR1616 50 mAh
16.0 x 2.0 mm CR1620 68 mAh
20.0 x 1.6 mm CR2016 80 mAh
20.0 x 2.5 mm CR2025 150 mAh
20.0 x 3.2 mm CR2032 200 mAh
23.0 x 2.0 mm CR2320 150 mAh
23.0 x 2.5 mm CR2325 190 mAh
24.5 x 3.0 mm CR2430 285 mAh
24.5 x 5.0 mm CR2450N 540 mAh
24.5 x 7.7 mm CR2477N 950 mAh
  • 1 year later...
Yeh, I noticed that....doh! :lol:
I'll add them shortly.... :taz:
Nearly two years later :lol::lol:
I've added a page to my electric-watch web site. Hopefully people will find this useful.
http://www.electric-watches.co.uk/batteries.php
Paul
  • 6 months later...
Ive just been trying to find info about the AG range as I needed an AG3 and an AG13... might be worth adding that... I found these so far:
AG1 = 364
AG3 = 392
AG4 = 377
AG5 = 393
AG12 = 386
AG13 = 357
The 3 and 13 measure up fine against the ones I have here but ive not tested this info for the others....
Ahha I found a table of these AG's now
AG0 379 SR521 LR521
AG1 364 SR621 LR621
AG2 396 SR726 LR726
AG3 392 SR41 LR41
AG4 377 SR626 LR626
AG5 393 SR754 LR754
AG6 371 SR920 LR920
AG7 395 SR927 LR927
AG8 391 SR1120 LR1120
AG9 394 SR936 LR936
AG10 389 SR1130 LR1130
AG11 362 SR721 LR72121
AG12 386 SR43 LR43
AG13 357 SR44 LR44
  • 6 months later...
I am changing a battery for a pal and its marked as Alkaline L926. I searched here but can't find a reference to 926.
I did find a website which shows the Silver Oxide 395 is also reference as various including L926.
You may find this a stupid question but are alkaline and silver oxide interchangeable? Is it the dimensions, voltage and capacity that are important? Do alkaline have a longer life?
  • 1 month later...
  • 3 months later...
I know this thread has been dormant but...
I change 20 - 30 watch batteries a day.
I have found this:
Renata Batteries leak after a while and corrode the contacts. I think its something to do with high temperature conditions. I have seen too many watches needing new movements just because their Renata cells have exploded and ruined the entire watch.
Alkaline batteries should be avoided just because they last 3 seconds and are usually made by some company in Thailand that put "Button cell" on them. They also leak and make bad things happen.
Seiko or SII batteries seem to be brilliant.
All batteries have a shelf life, if you leave a Silver Oxide cell in its package for years its going to loose a large percentage of its charge every year.
  • 1 month later...
  • 3 months later...
I'm really hoping someone can help me as I'm trying to find out another name for the CX927 watch battery. I've had a look around on here and online, but can't seem to find anything definitive out. I went to a jewellers last year who didn't have the CX927, so suggested a Renata 395 instead, but they've just shorted out and weren't exactly the same battery anyway. Any help you can give me would really be appreciated, and thanks in advance for doing so. :)
  • 2 months later...
Did you ever find this battery? if not try Roy sales@rltwatches.com
  • 1 month later...
  • 1 month later...
