pg tips
Acrylic Polish Pictorial
resurrecting an old thread as I just took delivery of my first tube of Polywatch! Anybody know if the stuff also works on scratched CDs/DVDs and plastic lensed glasses (e.g. sunglasses)?
The advice when using Brasso says to work back and forward in straight lines - is this also the recommended method for watch crystals?
Any and all advice appreciated
Dave
I always use a circular rubbing motion ( steady on at the back there )
It does work on CD / DVDs but I would be careful on sunnies as they often have coatings that would be rubbed off...
I use drawing pins to put part sheets of different grades of wet and dry (Over a cloth to act as a cushion) on a piece of good flat plywood for the scratches. Or if I'm not feeling tight, I just put in a new crystal!!!
Mike
This is a fantasic thread, thanks so much. I had to remove some scratches on my Oris pointer date.
Didn't have any Brasso to hand but had some Autosol and that worked spot on.
Great post, just completed my first acrylic refinish and am astounded with the results.
Thanks for taking the time to write up the tutorial.
OK - typical noob dumb question...
How do I know my grandfather's watch has acrylic and not glass crystal?? All advice appreciated.
It's a Seiko 5 Sportsmatic 6619-9990 - serial number is 6101572 (I'm guesing Jan '66) in fact here it is...
Seiko5Sportsmatic_6619-9990_iphone1
My link
Yours is an acrylic.
The "technical" way to tell i to tap them with your fingernail. If it sounds like tic tic tic, it's acrylic. If it sounds like tac tac tac, it's glass.
I also happen to know that tension/armoured ring crystals on vintage Seikos were acrylic.
tap it on your top front teeth, honest you can feel the difference between glass and plastic, acrylic feels warmer and softer too
I agree with Paul.....touch it to your top lip....if it feels cold it's glass,......if it feels warm, it's plastic/acrylic..........
Thanks Roger - here I am seeking guidance and knowledge from all over the world on the great wide interweb and I get words of wisdom from just a mile up the road!
I see what you mean about the temperature - my Christopher Ward and Breitling feel considerably colder to the touch. They're much less convex too - though that might just be styling.
Cheers!
I'm with PG Tips on this one. Tap it on your top front teeth. You can't mistake it. Its just so obvious once you've tried it.
<img src='http://www.wrist-watch.info/pgtips/timexnondate8.jpg' border='0' alt='user posted image' />
wow, looks good. i can't get brasso here in spain but i have found some similar metal polish which i added some toothpaste to and polished out light scratches on an oris i bough off ebay. quite successful.
i was a bit wary of using wet and dry but after seeing your results i might try it if i get anything with deeper scratches.
i also think rubbing the watch on the cloth not the other way aroung is the way to go, much easier i think than trying to hold on to the watch and rubbing the same direction with a cloth.
thanks for all the helpful hints.
<u>Now to polish.</u>
I use good old household Brasso and a Vileda cloth folded twice on itself (so it’s 4 layers thick).
<img src="http://www.wrist-watch.info/pgtips/timexnondate4.jpg" border="0" class="linked-image" />
Place the cloth on a hard level surface and pour a small amount of Brasso in the middle.
<img src="http://www.wrist-watch.info/pgtips/timexnondate5.jpg" border="0" class="linked-image" />
Now place the watch face down in the Brasso and vigorously rub back and forth (again no circles).
<img src="http://www.wrist-watch.info/pgtips/timexnondate7.jpg" border="0" class="linked-image" />
There is no need to press the watch hard down into the cloth, in fact you could crack the crystal doing this so just keep a light pressure and nice and fast back and forth. The fast rubbing actually melts the surface of the acrylic which is what gives it such an even polish when finished.
Pay particular attention to the edges, you may have to move the watch to an angle of 45 degrees to do this. Keep going all over, as long as you go back and forth you can go in all directions, i.e. 12 to 6, 9 to 3 etc until it’s had a good polish up. Then get a dry cloth and rub away the left over Brasso and you should have a nicely polished good as new crystal.
<u>The finished crystal</u>
this picture isn't the best as I've taken it under artificial light but it shows how good the polishing is. YES IT IS THE SAME WATCH!
<img src="http://www.wrist-watch.info/pgtips/timexnondate.jpg" border="0" class="linked-image" />
Hope this has been of help.
Just thought id through this one into the pot!
I always use T Cut after sanding, also works wonders on stainless steel.
Posting to bump up a great thread.
I just tried it with a beater Timex, when I say beater, I mean brutalized - you could barely read the dial.
500 grit, followed by 800 grit, then 1200 grit and Wrights Brass Polish (couldn't find Brasso around here)
You'd think it was a brand new crystal.
Followed it up with my 15 year olds watch, you can imagine the condition that was in. Another perfect crystal.
Now onto some of my better watches, although I'll probably do those with the crystal removed to avoid any mistakes/rubs on the cases.
Must admit this was my first job at tinkering (from this post) and it worked brilliantly good confidence builder.
that's great really helpful i was going to use polywatch i will give your method ago and see how i get on.many thanks and nice to see some step by step guides very useful :thumbsup:
I have a CASIO Waveceptor with some scratches in the crystal. I assume the crystal is plastic. I'm assuming that mineral or sapphire crystals would only come with a much more expesive timepiece.
If it's plastic, I'm thinking of trying Polywatch or fine grit sandpaper. I see where Polywatch is available on Amazon. Any opinions on the best buys (manufacturers, types, etc.) for sandpaper?
Thanks,
Jeff
I am just about to attempt to clean up a Rotary crystal, what I would like to know is how much pressure do you use on the wet & dry, light or heavy. or does it not matter.
just do it light and let the wet and dry do the work, dont go ape -remember you are polishing a type of plastic, too much pressure and you will break it , for deep scratches that need sanding i remove the crystal and use the reverse method (lay the wet and dry down and rub the crystal on it , same for polishing -i use a piece of felt with autosol (or whatever cutting compound you are using) and rub the crystal on it rather than the other way round , i find it easier.
Edited by pugster
